Another question about upgrading (key learns, etc)
capitan mission
Unread post by capitan mission » 16 Mar 2011, 07:48
Hello, Nay gave me some tips the other day. When upgrading just unpack the new usine in a new folder and load the previously saved Global setup/master settings.
I created a new folder for my library (for all my patches and the downloaded ones)
This worked OK, but one thing doesn't: the key-learns & the Quantize options are lost.
I'm doing something wrong? The wkp´s works ok, so i supose the key-learns and the quantize options of the tracks are not saved with them.
Unread post by nay-seven » 16 Mar 2011, 08:56
hello capitan
you can use the global remote for this [ ctrl+F4] ,
use : file/save as and save your personal midi &key learn, it's the same way than for the global setup
Users browsing this forum: No registered users and 378 guests
