Hello guys,
I'm using a midi controller ( UC 33) with the conductor. The volume fader value is stored with conductor. My problem is : when i modify a fader volume value manually after i recalled a scene with the conductor, my fader jump randomly.
i give an example : let's say i moved the fader manually to 30, later on i recall a scene from the conductor which go to 90 without any manual manipulation. then i want to go down manually to 80, the fader will jump from 90 to 30 which cause a brutal loss of gain! how can i avoid this ??
Jumping fader
i suppose the uc33 is not a motorized controller...?
so i don't see reel workaround cause the uc33 can't adapt itself to your presets..
the only think i see right now is to add a smoother module after your fader to avoid big jump.on the effect you control.?
noise2sine
Yes why not ?
My wish is to be able to use my UC 33 as smooth as an analog mixer !!!
how does it work ???
I have to precise that the fader volume i'm talking about are the fader from the mixer from the grid mode.
just insert this module ( modules/data/smoother ) between your fader and the inlet of the parameter you want to control and set the smooth value as you feel ( it's in milliseconds )
act like the fade option of the conductor...
edit : so use the module interface control/usine panel/mixer track output
Users browsing this forum: No registered users and 294 guests
