Posted: 19 Feb 2011, 02:32
Hi there. I've been playing with Usine a bit, and I really enjoy it. When I am able to get it to work, that is. I'm not sure if I'm just missing something in trying to get Usine set up, but I keep running into roadblocks.
First, I can't use it as a stand alone because whenever I close it, it blue screens. I spoke with Olivier about this issue before, and it seems to have something to do with my interface drivers (Mbox2). This is fine. I can live with just using it as a plugin.
I've been using it as a VST in Reaper. Usually it will work well for about 20 minutes before I start running into issues. I downloaded the synthesis pack and started playing with it. I found that if I open one of the VST interfaces with the "open VST" button, then press the same button again to close it, the plugin won't respond anymore. I have to close down the whole session. After a certain point, Everything freezes up and I just have force quit Reaper. This is in a session that's completely empty except for Usine.
Can any of you offer tips, how to get better performance, get it to play nice with Reaper, anything like that? I'd really like to be able to use Usine reliably as part of my music.
Best,
-Zach
EDIT: Should mention. I'm on Windows 7 64-bit, but I run Reaper in 32-bit.
Best,
-Zach
