Posted: 31 Dec 2010, 18:07
i recreate here a question about he ohm64 from the user ZOUKOUPOMME, better to have a separate thead ..
ZOUKOUPOMME :
hello and welcome zoukoupomme !
first , maybe better to open a new thread for this, this way could be useful and easiest to find for others omh64 users..?
now , i need some precision to help you :
_first, buttons on the ohm64 are in toggle mode? , i mean without Usine you can have on/off position yet..?
_then in Usine you can use midi learn on your switch , then right click and choose remote mode toggle
_now if you want remote this usine switch to your ohm64 , right click on this switch /find in remote panel and activate the remote button
_you must have select your omh64 as midi out in your global setup/midi out and activate also the remote function here..
tell me..
ZOUKOUPOMME
ZOUKOUPOMME :
nay-seven :Hi
I just had " USINE 5.25" .I have recently a controleur " ohm64 " .I would want that the leds of this last one remains lit(switched on) when I assign them has a button " play "or" lapel(backhand,lapels) " for exemply. I have to try to follow advise(recommend) them " to pilot external devices " of your wiki doku, but without resultat.
Have-you a solution has my probleme?
I thank you for it beforehand.
Je viens d'aquerrir"usine 5.25".Je possede depuis peu un controleur"ohm64".Je voudrais que les leds de ce dernier restent allumée quand je les assignent a un bouton "play" ou "revers"par exemple.J'ai essayer de suivre les conseilles dans"piloter des appareils externes"de votre wiki doku,mais sans resultat.
Auriez- vous une solution a mon probleme?
Je vous en remercie d'avance.
tell me..
ZOUKOUPOMME
Hello nay-seven!Thanks!
- for the buttons of "ohm64" I have the choice between: "note" or " control " but not toogle
- for "usine" I chose " toogle mode"
- I have make reglages in " global setup " .
But her(it) that does not work.sad
