Page 1 of 1
Posted: 29 Oct 2010, 10:14
by SylvainT
Hello everybody,
Here's my problem, I had a MacBook, with FireWire 400, running Windows XP and Usine without any problem.
I change the computer, for a MacBook Pro, Core i7. I install Win Lsd SP3, run Uisne with ASio4All and everything fine. Then I install the sound card (my old MOTU 828mkII) and it doesn't work. I have FireWire 400 to 800 adaptateur, think the problem is there, but the MOTU tech said It would work.
So I tried to find information on forums. Somebody said that SP3 "kills" the FireWire 800. It looks like there is a configuration problem with the SP3 and the FireWire 800.
Does anybody understand my problem? Do you meet this problem? Do you have a solution?
I think I'm f...d up, and the solution for me is to use Windows7 (argh money money) or maybe finding an old version of win lsd SP2 (without be sure it works).
Posted: 29 Oct 2010, 10:48
by nay-seven
yep, always difficult to help with non official version of windows , cause we never know if it came from the release or not...
Posted: 29 Oct 2010, 11:25
by 23fx23
there was a knowsn issue that SP2 messed the Firewire by default, and
there was a registry key to edit to make it like it is on olld behaviour , or a correctif patch on Microsoft site. it's pack 88522.
so maybe the same happened with SP3 and Fw800, have to check..
correctif FW on microsoft french site
