Page 1 of 1
Posted: 20 Oct 2010, 18:19
by sunhome
Ok, I am onboard having just bought a Pro License!
Can I just load the Usine Piano roll when uisng the vst version? I am using Cantabile as my host; The one thing I have been wanting for Cantabile is just a piano roll.
Using Usine as a vst, I have learned how to add the paino roll module and then setup the midi out so it does work. But I am a bit curious, since I have to go through a few steps is there any way to only get the piano roll to open instead of going through the Usine main screen?
Regards, James
Posted: 20 Oct 2010, 18:22
by sunhome
I also would like this for screen focus and open only ability for some of the midi add-ons like "smartusines", "rhombusine", etc ... Kinda like they were vst's that I was opening inside my host with just a click of one button.
Regards, James
Posted: 20 Oct 2010, 18:26
by nay-seven
no, sorry
the piano roll is a module of Usine so you have to run Usine to use it..
but welcome in the gold members world...:)
Posted: 20 Oct 2010, 18:28
by nay-seven
and of course same answers for addons...but who knows ..maybe one day
by gurulogic
Something like this? Image
edit: I'm half asleep, there's a better way. Assuming this is what you were trying to do?
Posted: 20 Oct 2010, 18:38
by sunhome
Thanks for the answer. Btw, where are the demo workspaces located?
Regards, James
Posted: 20 Oct 2010, 18:43
by nay-seven
you mean : Usine pro standalone 5.25xx/files/demo...?
Posted: 20 Oct 2010, 18:55
by sunhome
nay-seven wrote:you mean : Usine pro standalone 5.25xx/files/demo...?
Ok - I am gald there are sample projects to learn from. It seems in the Usine browser I do not see the demo files to load thus my question; In windows explorer as you mentioned in the Demo folder I see lots of I see there are lots of .pat projects to workthrough.
Regards, James
Posted: 20 Oct 2010, 18:57
by sunhome
I plan to print out the manual and the quick start manual this week, but thanks for the help as I am now listening to the demos :)
Posted: 20 Oct 2010, 19:08
by nay-seven
just a tip : gurulogic give me the idea , :
in cantabile next the piano , on the left you have 4 button , right click on one and choose customize / choose the midi controller number you want
in Usine add a switch to the visible inlet of the piano roll
right click on it choose remote mode toggle and then midi learn it with the cantabile button..et hop
you have a button in cantabile who open the piano roll...
Posted: 20 Oct 2010, 19:15
by nay-seven
update : you have to minimize the Usine window, this way Usine don't open over cantabile when you click again on your cantabile button to hide the piano roll...
Posted: 20 Oct 2010, 19:45
by nay-seven
in, fact when you'll be more easy with Usine you'll see that you can do the same with addons, putting them in container and link the switch to their visible inlet..
Posted: 20 Oct 2010, 19:53
by sunhome
can't seem to get to "right click on it choose remote mode toggle" so I attached a picture where I got stuck at
Posted: 20 Oct 2010, 20:03
by nay-seven
no , my fault :you have to right clik on the switch but on the control panel :
Posted: 20 Oct 2010, 20:07
by sunhome
LOL, I probably won't use the piano roll as much as the add on sequencers ... as the add ons look like more fun :) However the answer for the piano roll would be the same for the add-ons, so again thanks for the help.
Also I am starting to consider the possibility that of a Usine add-on like http://matrixsynth.blogspot.com/2010/06 ... -midi.html would really make my setup fun.
Regards, James
Posted: 20 Oct 2010, 20:49
by caco
sunhome wrote:LOL, I probably won't use the piano roll as much as the add on sequencers ... as the add ons look like more fun :) However the answer for the piano roll would be the same for the add-ons, so again thanks for the help.
Regards, James
Welcome aboard James, cool link it reminds me of a software Synderphonics Manta :)
Posted: 20 Oct 2010, 21:42
by sunhome
actually, the developers website has more info on ijammer [ in comparison to my earlier url posted ]
http://www.tradlessons.com/iJammer.html
