UsineVst output
manecante
Unread post by manecante » 10 Sep 2010, 15:17
Hello!
i am trying to use usineVst in Ableton Live and i don't understand how to route the sound of the the whole project in Usine using multiple tracks, on the first output of the soundcard..
Here the set up:
i put the vsti version of usine on a midi track in Live.
then i open my project, but only the first track is output on the first output of the soundcard, the other ones are respectively output according to their tracknumber.
As i want only one stereo output, should i make a little patch myself or is there a smarter solution?
manecante
Unread post by manecante » 10 Sep 2010, 15:24
oups, sorry, just got it..
on each track there is the "out" option where you can choose the output, that i forgot!
gurulogic
Unread post by gurulogic » 10 Sep 2010, 18:28
Another solution is to place a Usine VST on multiple tracks in Live and then you can mix each Usine track from the Live mixer.
And don't forget the Additional Audio Output module can be usefull for sending audio direct from any patch to the output of your choice.
Users browsing this forum: No registered users and 25 guests
