Posted: 28 Jan 2007, 14:46
Hi Usiners,
Back again with my questions...sorry ^_^
I've just read in the manual that Usine's samplers were able to play samples simultaneously...what is called polyphony.
You can even chose the number of samples that can be played ! Wicked !
But how do you do that ?
I'm using this soft without MIDI stuff, just my laptop and soundcard...so I tried to set up some patch that could help me but...no way, I can't trigger 2 samples on one sampler simultaneously.
Any ideas (or explanation)?
Could (once again) a MIDI keyboard solve this problem ?
Another point I wanted to ask you : I'm trying to trigger a sampler with 2 methods, I have a single button (linked to play of course) but also a step sequencer (also linked to play)...and just as I thought it doesn't work 'cause both signs just collide. I tried to add an "or" and "xor" module but problem isn't solved...if you have any ideas, you're welcome !
