Page 1 of 1
Posted: 13 Apr 2010, 09:24
by noise2sine
I'm using the version 5 of Usine with the grid mode and the sequencer at the same time. Each time i'm loading my workspace, i have an Internal error message ! and if i delete those files waves files i don't have this message while loading the same workspace.
The thing is that i'm planning to set up my live set and loading a lot a waves files and setting up loops so i want to be sure that this type of message won't block me at one point !
Is there a better place where i should store the waves files which will be loaded in the sequencer ?
Posted: 13 Apr 2010, 11:18
by nay-seven
strange , did this error message in the console concern wave files you use in the sequencer or..?
maybe an external drive..?
Posted: 13 Apr 2010, 13:44
by noise2sine
Yes this error concern a wave file in the seqencer and this file is located on my laptop hard drive not on an external drive.
Posted: 13 Apr 2010, 22:33
by senso
This pb looks strange.
normally you can store you can store waves anywhere on your computer, or network.
Files are stored in with their absolute path.
But if a file is not found Usine looks into (in the order):
1) the current patch folder
2) Usine/Files/demo folder
