Page 1 of 1
Posted: 07 Jan 2007, 21:31
by nay-seven
hello all,
i'm working on a midi vst tool and don't have find a way to filter midi canal in Usine , i mean my vst send infos on 3 midi canal and i want send the midi out to 3 different vsti
so maybe there's a way in Usine but can't find it..;)
so i've built this little vst , just load an instance for each canal filter you want , then click on it to choose your canal
if you need this little tool just find it in the add-ons section
Posted: 08 Jan 2007, 09:13
by senso
thanks for the midi filter dll.
works great!
You can post it as an add on?
Normally with Usine you can create a channel filter with a stop 'event flow' and few 'math/logical' modules.
But it's more clear with your vst.
Posted: 08 Jan 2007, 12:37
by nay-seven
ok, no problems
just add it...;-)
Posted: 08 Jan 2007, 15:29
by senso
cool!
