I put a led over a switch. It works until I re-open the workspace, then the led is hidden behind the switch. How does it work ?
Overlapping interface design objects : what's the logic ?
yes, not easy..
put your led in a sub-patch..this will work..
La Tenaille
tested : ok
Users browsing this forum: No registered users and 211 guests
