Page 1 of 1
Posted: 08 Jan 2010, 21:01
by Alain Vankenhove
En français dans le texte : salut, ne serait-il pas possible de faire évoluer tout ce qui est piano roll, au même niveau que l'exploitation de fichiers audio. J'aimerais enregistrer en temps réel des boucles midi, ça OK, les recaler sur un beat par automatisation ou pas, si il s'avère y avoir un peu de décalage, passer d'un chiffre à l'autre, donc d'une boucle à l'autre aisément, via key learn ou midi learn dans le seul but de, par exemple créer en temps réel des lignes mélodiques sur une pattern rythmique, de passer de l'une à l'autre facilement, et tout cela dans un monde calibré midi. Dis -moi ce que tu en pense Olivier, et ... bonne année 2010!
Alain,
hello, it would not be possible to bring some change in all that is roll piano, at the same level as the working of audio files. I would like to record curls real-time midday, this OK, to fail them on beat by automatization or not, if there proves to be be a little of gap, pass from a figure to the other one, therefore from a curl to the other one easily, via key learn or learn midday in the only purpose of, for instance create melodic lines real-time on a rhythmic pattern, to pass from one to another easily, and all that in the world calibrated midday. Say - me of what thinks you of it Olivier, and happy new year 2010!
Alain,
Posted: 08 Jan 2010, 22:35
by nay-seven
piano roll of the V5 have many improvements you 'll like i suppose
but have you yet tried to play with num file inlet for changing pattern and using button synchro mode and link this play button to a master synchro..?
could be a direction..
Posted: 27 Jan 2010, 16:23
by Alain Vankenhove
thanks, I try soon time for understand much better synchro mode, now I have an another problem.
Conductor change parametre but not Program Change on Vst ? (Drum on Reaktor for example) and not preset on Ben Groove Box demo. It's not possible to change this?
Thank you for advance,
Alain,
PC F7- dual core 2 X 2 Ghtz; 2 Go de RAM, XP SP3; Konnekt 24D, BCF 2000, Axiom 29, MPD 24, FCB 1010
Posted: 27 Jan 2010, 16:35
by Alain Vankenhove
preset change on Ben Groove Box but on visual, it's just this problem. For vst ok, there is no solution ?
Alain suite,
by Alain Vankenhove
Alain Vankenhove wrote:preset change on Ben Groove Box but not on visual, it's just this problem. For vst ok, there is no solution ?
Alain suite,
Posted: 27 Jan 2010, 18:01
by nay-seven
for reaktor add a combo box to the program inlet like this
this will solve the problem :
Posted: 27 Jan 2010, 19:27
by Alain Vankenhove
thank you a lot !
Alain,
