Hi
There is audio clic when track mute is set on.
Is it normal ?
Can we improve it ?
regards
charles
Audio clic with track mute
- nay-seven
is it normal : no
can you improve it , yes....
, try to change your setup / best block size / soundcard buffer size...graphic setup
cybercharles
Up to me in 99 % of the audio software MUTE is present as a primary element !
I don’t understand why in Usine you have to deal with the setup or your hardware config to have a simple audio mute without clic ….
sorry but i'm a little beat disappointed with your answer !
t
- nay-seven
i understand your reaction , but i've same problem than you with my old Edirol UA-20 and asio4all on my internet computer
but no more click on my "music" config " computer with a good soundcard and only Usine installed..
and don't forget , i'm not senso
- senso
Usine make a small fade in/out during the mute operation.
The length of the mute is equal to the setup/bloc size.
Why ?
Because when the fade-in is too long, the attack of the sound can be altered. which can be a problem in some situations, like starting a drum pattern.
This choice follows a long discussion somewhere in the forum....
so finally the user can choose the best crossfade for its own usage.
Why ?
