Page 1 of 1
Posted: 30 Jul 2009, 12:05
by cybercharles
Hi
If I want to edit an audio sample while USINE is open, WAVELAB return me a reading error message because my audio driver is still used (…in fact by USINE).
My sound card is an RME Fireface 400.
Is it possible or not opening both USINE with a second sound software? And How?
Regards
charles
Posted: 30 Jul 2009, 12:48
by nay-seven
try asio4all for your wave editor....;-) ,
Posted: 30 Jul 2009, 13:14
by ethnix73
RME driver might be multi-client. Enable different audio outputs within Usine and Wavelab...Or try the solution of nay-seven
Posted: 30 Jul 2009, 13:38
by bsork
Would it be hard to implement to something like the "Release ASIO driver in background" option in Cubase? Obviously not something to have on in a live setting... ;)
Posted: 30 Jul 2009, 15:19
by cybercharles
following ethnix advice I find a solution using RME matrix. In Wavelab i chose different audio output than USINE and with the matrix i drive the signal in my main monitor output (same as usine).
thanks guys
charles
