VST and Modules Menus are empty
rods
Unread post by rods » 18 Sep 2006, 16:20
I know this has already been discussed in this forum, but I can't find a way to make usine re-scan my VST plug-ins directory. I tried to change the path to diferents places but nothing changes.
(I have already asked here to stop usine from scaning the vst directory always on startup, now I need the opsosite...sorry...)
Rods
Unread post by senso » 19 Sep 2006, 13:11
I'm not sure I understand your problem.
Normally, when you change the VST path in the setup, Usine rescan automatically the new VST folder to display changes in the menu 'VST'. (works on all my systems)
If not, you can click right in the menu to precede a scan manually.
If the menu is still empty, it's probably because the original folder is empty or ...a bug...
Usine does a short VST scan, and I've decided to disable the deep VST scan to avoid some hard crashes posted in the forum.
I think that it's better now, more stable, and faster.
rods
Unread post by rods » 19 Sep 2006, 20:10
Sorry Senso. It was a confusion I made. I tested with some older projects and it worked fine.
I think it has to do with my understanding about the way version 2 is organized.
Everything is ok now.
Sorry for the inconvenience.
Rods
Users browsing this forum: No registered users and 188 guests
