help with joystick module
goyya76
Unread post by goyya76 » 25 Feb 2009, 01:12
hi all,
i used a usb joystik electronics to build a pedalboard with 11 buttons....so i can't use the Usine built in joystick module (cos it supports 4 buttons only) - i tried the joystick addon (thanks nay seven!!) but i notice it adds some latancy which does not fit with using the pedalboard live for guitar fx control.....
any suggestion?
i dloaded Rejoice 1.6, but after a while it shuts down (so i guess it's not freeware as i thought) - alternatives...?
Thanks all in advance,
Goyya :)
Unread post by 23fx23 » 25 Feb 2009, 01:26
http://www.otk.it/mjoy/
I I used to like this one but 6 buttons only, maybe as it supports 2 joys, don't think but worth a try...
Clearscreen
Unread post by Clearscreen » 26 Feb 2009, 00:30
could you use bidule and see the joystick with it's HID input module? that's about all i use bidule for these days...
Users browsing this forum: No registered users and 82 guests
