Posted: 13 Feb 2009, 23:43
Hi USINERS
I'm actualy using a MIDI filter module to filter MIDI chan as the simplest way by selecting the desired chan to filter in the last module parameter.
I have One MIDI wire connected in the module whith two MIDI channel data flows, only MIDI (ON/OFF) notes:
Channel 5 data and channel 1 data. (the channel number doesn't mater)
The module is filtering the Channel 5 notes and of coars the channel 1 notes are stopped (...just to be clear in my explanation).
I notice that when channel 1 data flow is very high (4 pitch notes whith low quantisation beat 1/32, 1/64...)
The module is responding strangely in the filtery process. He creat some times more note OFF than note ON....
I have to precise that channel 1 data flow for this test is very low (one same note every bar)
I guess there is a problem whith the module because when i mute upstream channel 1 data the module answer is ok ...
Do you have notice this problem ?
regards
Charles
regards
Charles
