Usine minimum config?
Vincent
Unread post by Vincent » 31 Jan 2009, 12:23
Hi all killers!
I'm planning to be perhaps the first crazy guy to run Usine at 2700 m, with a windmill, to make music for marmots and eagles.
This is the first step before an ESA/Army top secret program to run Usine on Pluton (with a cyanhydric acid mill) and to teach electronic music to micro-organisms we bring there, with no TV, no Web and no girls to disturb them from their work.
I've plan to "sacrify" an old notebook computer and to make tangible efforts to pollute new wild areas. I hope you'll appreciate ;)
I'll use an external audio USB interface, a beehive, bike wheels, chamois dung for the glue, and a handfull rusted screws...
What should be the minimum configuration (RAM, CPU...)?
Thanks!
vincent michel
composer & novelist
Unread post by nay-seven » 01 Feb 2009, 19:01
some times ago , senso show us usine running on a eepc , ( and it was first generation )
so i suppose it's agood example of light config...?
Unread post by senso » 02 Feb 2009, 17:19
Yes I'm working on a project with 5 eeepc on stage connected together by wifi. works like a charm...
Vincent
Unread post by Vincent » 02 Feb 2009, 17:37
OK, thanks guys, that gives me some space before fringe.
I won't make an eeepc cluster, since the whole "aparatus", including electricity production, should fit in a beehive. But I keep it in mind for another mission.
cheers.
vincent michel
composer & novelist
Users browsing this forum: No registered users and 1679 guests
