Page 1 of 1
Posted: 12 Nov 2008, 23:10
by cybercharles
Hi Olivier
When i select a MIDI wire
there is two type of data
MIDI data for exemple [xxxx:o ON 35 120 c1]
and some time between MIDI data there is [yyyy:[0]]
what are this type of data ? (just to informe, this are not filtered by the MIDI filter modile)
are they a problem if you transmit it to a VSTi for exemple ?
I'm trying debuging a patch...
Charles
Posted: 13 Nov 2008, 08:43
by bsork
I'm not quite sure, but I think it's a way of showing that the MIDI array is empty, ie length=0. I'm pretty certain that it isn't anything to worry about.
