Problems with LiveSlice vst
Danilo_Bovi
Unread post by Danilo_Bovi » 20 Oct 2008, 14:24
Hi! How are you?
I can't navigate in the folders menu of liveslice vst (from livelab) in both the version of usine (3.xx and the 4beta).
When I click a folder, the vst opens another one. It's very strange.
In other hosts (like sonar, vsthost, aodix and ableton live) it works perfectly.
Thank you in advice and good patching to everybody!
Unread post by senso » 20 Oct 2008, 15:08
It works only if you activate the patch.
Usine totaly disable VST's when the patch is OFF. It's cool because you can load a vst without using any CPU but has drawbacks on some rare vst (which are waiting for Usine to receive 'paint' event).
Danilo_Bovi
Unread post by Danilo_Bovi » 20 Oct 2008, 20:18
Great! Thank you for the reply Mr. Sens!
