Hi
I have some audio files in the sequencer, and I want to move them alltogether...so I choose "Select all" and drag and drop them with the mouse, but now I'm finding the items are not anymore in sync each other...I'm missing something?
thanks
Sequencer: moving items
Actually when you move several objects all of them are snapped according the 'snap' option : none, grid, object.
So they can lose their relatives positions except if you chose the snap=none
It's tricky and I'll change it in the next version.
the automatic snap will be disabled when several object are selected.
More programming I'm afraid, but...: What if you "anchor" the chosen snap option with the first patch in the selection, and retain their relative positions to that?
yes it the best solution.
Users browsing this forum: No registered users and 155 guests
