Page 1 of 1
Posted: 14 Sep 2008, 13:00
by ethnix73
Am i wrong or does the preset manager module does not store values for subpatch?
Posted: 18 Sep 2008, 00:43
by ethnix73
Edit:
Preset manager doesn't seem to store directly values for sub-sub patch.....but some workaround might be possible i suppose.
Posted: 18 Sep 2008, 14:26
by senso
you're right.
It's probably time to change the Preset behavior to feet to new possibilities of Usine.
Posted: 18 Sep 2008, 23:57
by Vincent
Hi ethnix73,
The PM stores the values of the controls in the same patch.
For sub-patches, I would suggest 2 solutions:
- connect controls to the inlets of the sub-patch - and their values will be stored in the PM
- add a PM in the sub-patch and make it work in parallel with (or chain it fully to) the main PM ('num', 'store', 'recall', and so on). I must say that I never tryied this one!...
I hope it helps.
Posted: 19 Sep 2008, 01:07
by ethnix73
i've just done what you suggest in your second solution. We had same idea.It works fine...
