dumb question by a new user
I need some help.
Midi out is not working, I can't hear any midi sounds, only wave.Maybe I'm doing something wrong configuring midi in usine but don't know what.It's not a hardware problem because everything is working fine whith Reaktor and Live in the same computer, the same keyboard and asio.
Mkraiser
I need some help.
Mkraiser
Did you configure your midi out and in global set up?
Seb.Dub
i've done a little flash file ( it's maybe a test for future help file ) showing a way for a little test to do to check this ...
http://nay-seven.com/beta/midi%20out%20control.swf
thanks for replying.
I'll check again global setup and nay-seven video.
mk
mk
i've update the wiki / how to
with a little test tutorial :
" How to check my midi out works "
Now it's ok, I have a lot to learn about usine...
MK
MK
Hi there, I'm thinking of defecting from Audiomulch to Usine and I was wondering if current users could advise me. Basically, I'm processing a modified electric guitar/wavedrum with vst plugins and need to be able to leave one track fading out while starting a new one. Kind of cross fading from one to the other. The 2 tracks may well be at different tempos though and I need to synchronise delay/chopper effects to each tempo. So I culd have a synch delay fading out at 110 bpm and a chopper plugin for another track synched at 125 bpm. Is this possible?
Blugaruda
Blugaruda
Hi blugaruda and welcome,
You can use the Local sync module (Synchronisation&Time menu). It can provide you a local synchro for each sub-patch, patch, track, independant from the master tempo...
Don't hesitate to create a new thread to ask specific questions.
Seb.Dub
Ok. That sounds great. I will delve a little more - thanks for your help
TygermanGB
Security says I have to reply before I can post. This looks like as good a place as any.
Cheers,
-Ty
www.soundclick.comtygermangrooveband
Cheers,
-Ty
Clearscreen
nice to have you on boardTygermanGB wrote:Security says I have to reply before I can post. This looks like as good a place as any.
Cheers,
-Ty
Users browsing this forum: No registered users and 333 guests
