Hello, bravo, bon synth? et bonne apn?e...
I've juste seen the 2.69 version wich I'll try tomorrow morning as the sun arise, on the previous version, I never found how to save an extrept of a sample :
I record a 10 sec sample, wich I loop, then I ajust the starts & end of my sample (let say start 20 % end 70 %) and then I want to save THAT sample (wich is 5 sec long) and not the whole sample so I can repeat this operation several times (several recording and many cuts latter) and put my "cutted" samples into an aleatory engine sampler wich will let them live by them selves while I can do some other great things on this ultra-great software exciting for that grey substance we have in the brain.
my english is not better this year than the previous but I'm full of good wills
saving some of a sample
Actually, it's impossible to save a part of a wavefile in the sampler.
I'm working on a small wave editor in Usine that will allow this kind of features.
Be patient...
Be patient...
Thanks, I'll wait patiently ...
Usine keeps an unbelievable software, so powerfull & so light !!
I can't believe you can make so many new version ...
Users browsing this forum: No registered users and 181 guests
