Midi chords....
noise2sine
Unread post by noise2sine » 20 Jun 2009, 00:05
i'm looking for a software or freeware in order to create midi chords. For example if i need a A major seventh chord i simply click and i get the chord. i have already tried tone space and chord space and i didn't find them really efficient for my purposes.
thanks in advance
Unread post by nay-seven » 20 Jun 2009, 00:12
I've suggest recently this one :
http://azertopia.free.fr/Supermidiscripter.html
maybe it can do the job for you , you also have the script of usine of course..
Unread post by 23fx23 » 20 Jun 2009, 00:29
it must be easy to do this with usine, pre enter the chords intervals and make buttons that will trigger the two other when you press a note no? do you play from external keayboard or you want buttons to create chords?
noise2sine
Unread post by noise2sine » 20 Jun 2009, 10:19
hello, thanks a lot yr attention!!! what i need is a tool for composition, i won't play with external keyboard. Concerning the script i'm not at a level i can built my tools scriptwise. What i need is as many chords type with inversions in all keys and then i'm listenening some guitar improvisation i have recorded (drone) and choose different chords by clicking on the midi chords processor until i find the one that fits according to my ears. So i click again (or different) and the chord is recorded in midi in the piano roll :) . it can be good for creating original chords progressions
Thanks for yr help Usiners !
Unread post by senso » 20 Jun 2009, 14:26
a long time ago I made a small utility called composer.
you enter chords on a grid like D-7 G7 CM7 A7#9 and the soft plays the chords in tempo.
maybe it can help I'll post-it in as soon as possible (next week)
noise2sine
Unread post by noise2sine » 20 Jun 2009, 18:53
it will be good to try yr Senso program ! and for sure others idea will be welcome !!!
amiga909
Unread post by amiga909 » 21 Jun 2009, 13:59
there are various midi chorder vst plugins that can do the job.
some free candidates:
az audio domaj // small+ easy
topza chordworx
ChordSpace // advanced still easy
http://www.chordspace.com/ChordSpaceindex.htm
mucoder hypercyclic // maybe the best arpeggiator around, also does chording
mucoder tonespace // complex chorder
http://www.mucoder.net/hypercyclic/
noise2sine
Unread post by noise2sine » 22 Jun 2009, 23:15
thanks nice for the tips nice green frog !!!!
Users browsing this forum: No registered users and 333 guests
