hello,
i was working in a workspace,and at the moment i can't reopen that workspace. I really need to get back some patches inside.
how can make it ? what is the wkp-old file ? how can i open it ? would it be usefull for gettinfg those patches back?
Cheers !!
WKP-OLD hope !!
- nay-seven
yes , just rename it as for example test.wkp and it will open , in the file/ temp dir you can also found some undo patch , save them in an other dir and try to open them...
good luck
good luck
- nay-seven
cool
and thanks...
and thanks...
