conductor
have you check the " Tabbed panel example" ( first version ) patch of martignasse in addons/others/..?maybe can do the job..
Thanks nay 7. I have difficulty understanding the patch you suggest to transform it.
I tried conducting patch on/off which would be a good solution but the patch is still in the interface builder even when it is deselected or off, unfortunate on that point. Toggle won't work either obviously. Need a simple idea or maybe senso can fix that, I guess it would be classed as a bug,no? I noticed it was supposed to be fixed in beta 6 or 7, not with my version 10 in any case.
It seems quite important feature in a live situation with lots of different song settings when tightly arranged, not a hinderence for me when I do an improvised set at least.
Thanks for reading, happy to read any other suggestions.
regards steve
regards steve
thanks , i'll check as soon as possible...
Users browsing this forum: No registered users and 105 guests
