Minimal spec
fractal
Unread post by fractal » 04 Jan 2009, 21:15
Hi guys !
I'm a new "futur" user of Usine pro.
I'm a fan of Reaktor and i think Usine can be wonderful for me (sorry for my crappy english , i'm french and the school is so far now... :) )
I first lookin' for a Lemur (i have a monome 128 and Audiocubes from Percussa, i'm always lookin for a new way to make music.)
But it's a little bit overpriced for me...
And i discover Usine! (i think it's a little bit under exposed, make more videos, with each add-on for example... :) )
First question (but not the last!) :
What good tablet Pc for Usine? the minimal spec/performance (i want use it like a Lemur for Live and make my own control)?
i'm lookin for a Used Dell XT Tablet (650 euros) but 1,2 ghz scare me a little...
Have you some suggestion? my budget(is the good word?) is around 600-700 euros (no problem for used gear/Tablet)
Hope you help me :)
See ya !
Ps here my myspace if you want see some videos/tracks : http://www.myspace.com/fractaldeath
fractal
Unread post by fractal » 05 Jan 2009, 16:56
Houhou...y a quelqu'un...quelqu'un...qu'un...un....un....(écho de grotte :) )
Tant pis...
On verras si ça marche bien avec le Dell xt(vu qu'il gêre le multitouch).
A+
Unread post by nay-seven » 05 Jan 2009, 17:34
hello and welcome
sorry for the delay but it's really not easy to answer...
there 's not a good tablet for Usine , but maybe a good one for you...
depends on what you need..maybe depends on your soundcard too
my first impression will be to say 600/700 euros...maybe not enought , cause it's the price of medium normal laptop now...
you talk about an used one , maybe ask to test it with Usine if you can...?
fractal
Unread post by fractal » 08 Jan 2009, 04:14
Thank you Nay-seven for the info :)
I'm going to wait a little and buy a HP TX2Z ( very comfortable performance,2,4ghz 4gb,multi touch.the dell xt scare me with 1,2ghz...)
I successefuly fighting my computer...via Midiyoke(with my cubes software and monome software...to sync all this mess :what a party!)
And i started create some pretty cool things to control Ableton(synth/sample start totally crazy etc etc... :) )
Definitively a powerful beast, not easy to learn it, but SO POWERFUL !
I can't wait have my tablet i buy the pro version to explore the add-on and the beast
I have a little question... when i create a switch(mute/unmute a track on Ableton Live) i have to Click twice for mute or unmute...is normal or i miss something(well i'm pretty sure ,i miss something :) )
And sorry for my bad english, sometimes one would say i'm like Borat...writing :)
Bye all !!!
Unread post by nay-seven » 08 Jan 2009, 07:07
cool for the HP..
for your last question , depending of how you're patching your mute switch but you can add a toggle ( event control) just after your switch..
fractal
Unread post by fractal » 12 Jan 2009, 13:51
Hummm i'm going to try this.
But i have some latency too (i use Usine like a Dream remote for ableton Live)
When i push(click with the mouse for the moment :) ) sometimes i have to click twice and sometime one push is good but with latency...
In the message center of Usine i have sometime in alternance : OUT:?
i have put midi out 1 to midiyoke 1
and midi out 2 to None
maybee this?
Other question, i try to build a X-Y to control my filter in Ableton but i don't know how i have to build this....if you have some example for me(i'm a super noob in building patch, i try my best...)
,thank you ;)
Unread post by nay-seven » 12 Jan 2009, 18:53
don't think there is a link with your midi ports... ,don't know...
for the second question : xypad module , to the X outlet , add a multiply module ( maths: a*b ) and use 127 for b
and link this to a data 2 of a " create midi" module ( of course choose "control change" and the number of your midi controller )
link it to a midi out module
do the same for the "Y "outlet
and for finish , add a " has changed " module ( in control events ) between the X outlet and the "create " inlet of the midi create
do the same for the Y...
hope it's clear enought...
fractal
Unread post by fractal » 15 Jan 2009, 14:29
Thank you Nay-seven !
absolutely clear !
I'm a noob on patching some midi module in Usine but i try my best and hope one day i can help like you help me ;)
fractal
Unread post by fractal » 18 Jan 2009, 14:21
Arfff...
Don't work.... i don't know...(in Usine pro all XY pad ; bouncing balls etc etc are ready to use in Midi mode ? )
here a screenshot :
What's wrong?
thank you for help :)
Unread post by nay-seven » 18 Jan 2009, 14:58
your picture is not easy to see but seems that no " has change" and others..
here how i see your wish : this way , you have 2 controllers , one for X , an other for Y :
fractal
Unread post by fractal » 18 Jan 2009, 16:12
Yeahhhhhhhh !!!!!
Work perfect !!!!
Just awesome....AWESOME !!!!
Thank you sooo much Nay-seven :) hip hip hourray for you !
I re-discover my synth(Vst) , you can make so weird and cool control with Usine(control filter master with wavetable and lfo in a Synth via XY pad!!! )!
Usine is great! so Great !
Users browsing this forum: No registered users and 381 guests
