change track order
julien_
Unread post by julien_ » 03 Dec 2008, 11:19
hello all,
very simple question...
is it possible to change track order ? i would group my effects track in two first track but i can't do it
thx
Unread post by bsork » 03 Dec 2008, 11:45
You can't, but you can drag patches around in the grid (ctrl-drag to copy), or you can save the whole track in one file and import it (see the Track menu).
La Tenaille
Unread post by La Tenaille » 16 Dec 2008, 10:19
I'd like to change track order too (insert a new track at the begining to be precise).
My trouble is I've made a lot of conductor learns (switch states, presets, etc...) and moving a patch deletes all my records...
Any tip?
nofish
Unread post by nofish » 16 Dec 2008, 15:49
+1
and while we are on the topic...
I'd like also an option to minimize tracks in width, so that they all fit on screen.
With 10+ tracks I have to do a lot scrolling. (Or did I overlook something?)
Unread post by senso » 16 Dec 2008, 16:31
all this features will arrive in the v5.
I'm already working on.
Clearscreen
Unread post by Clearscreen » 18 Dec 2008, 02:22
senso wrote:all this features will arrive in the v5.
unbelievable - you never stop do you!! :)
Users browsing this forum: No registered users and 62 guests
