Touchscreens Lemur and Osc
Hi all,
Thanks for the program! Its´great; but i´ve runned into some questions:
a) Can Usine host vst´s while in vst mode
b) In Standalone mode, is it possible to load vsts (like reaktor) and control reaktor parameters with a touch screen? Meaning not having to configure every parameter, just touching it trough the touchscreen.
C) I own a Lemur and I was wondering if it can be used as a touchscreen with Usine, and how are you guys using it with Usine. Do you have to create new objcets on The jazzeditor and Osc target these, or is it done inside Usine?
Thanks for your time
Thopa
Thopa
a) Yes.
b) The touch screen only mimicks the mouse anyway, so you can use it directly on any VST's GUI. I don't have any touch screen myself, but I suspect there might be some problems using fingers to control small GUI objects, though...
c) Someone else has to answer this.
hello
a ) yes you can
b) i think the best way is to create your own controls ( knob , fader and so ) to control only the reaktor's parametrers you need , that's more the Usine way / feel...
c) can't answer to this one , don't have one...
a ) yes you can
ha ha , you win with 34 seconds bsork.....
thanks, Ill try to find out aobut the copmpatibily with the Lemur
c) in the addons/other section you'll find a set of ready made patches to communicate with a lemur in osc.
But the lemur is not a screen!
Users browsing this forum: Google [Bot] and 231 guests
