Vst crashes Reaper and Cubase LE4
Anyone else having issues with usine vst/i crashing applications?
I can't get Cubase LE4 to load if it detects usine in the plugin path, it crashes. I delete it and Cubase loads fine.
Also in Reaper, it loads as an FX, but then at some point it just crashes the whole application.
I'd really like to use it as a vst replacement for Bidule, but it seems a little unstable.
Any ideas?
ty!
Any ideas?
ty!
Komuso Tokugawa
Bringing the Boogie to the Bitstream
strange ,
can't tell you for Cubase but i don't have any problem with Reaper..
when crash appears , have you only Usinevst running or other vst too( inside Usinevst or in reaper )..?
Happens in Reaper in both cases.
Komuso Tokugawa
I had a problem with the previous version in Reaper.
Haven't yet tested the new version of Usine.
please report bugs by mail! contact@sensomusic.com
thanks.
thanks.
Maybe not of much help Komuso, but all the versions I've tried (3.xx and 4.00 up to beta4 or beta5) works in Cubase Studio 4. I fairly sure that the audio/VST engine "under the hood" in all Cubase 4 versions are practically the same.
BUT: I just thought of something that might apply to the problem with Cubase LE4. If I understand you correctly, LE4 won't startup with Usine in the VST path. LE4 has AFAIK a restriction on the number of VSTs that can be loaded simultaneously (4? 8?), and Usine will run as up to 10 (16?) plugin instances. Maybe that's what causing it. You could try to load the limited, free version and see if that works.
no, I don't think that's the issue. It's loading a blank project, just scanning the vsts on startup.
Not sure what is up with either as there are no log files to check afaik.
Komuso Tokugawa
Users browsing this forum: Bing [Bot] and 383 guests
