VST plugins issue
fanch
VST plugins issue
Unread post by fanch » 04 Nov 2026, 10:38
After successfully scanning for VST and VST3 plugins, they do not appear in the browser..
I close USINE, and when I open, nothing in the plugins folder.
What should I check?
Unread post by oli_lab » 04 Nov 2026, 20:40
did you point to the directory where your VST are installed ?
fanch
Unread post by fanch » 05 Nov 2026, 09:43
Yes I did
percuson
Unread post by percuson » 08 Nov 2026, 01:59
Actually all should be fine within Usine.
I don't know how experienced you are, so here is probably a stupid question:
Are your plugins 64-bit? because 32-bit will not work.
Did you also check, if they load in another program/DAW?
fanch
Unread post by fanch » 08 Nov 2026, 11:17
Yes, all plugins are 64 bits.
I'm working with Nuendo and Reaper, and no issue with them.
Within Usine scan is good, but After closing and then restarting, there is nothing under "plugins" in the browser..
percuson
Unread post by percuson » 08 Nov 2026, 23:11
I am usually not working with plugins, but I sometimes had Plugins Usine didn't load. Just don't know if another DAW would.
In the Usine folder go to Config -> Plugins. There you find folders and .init files. In the folders there should be copies of the plugins. And the .init files you can read in any text editor. Probably you find some information there.
You could also just try with a freshly unzipped Usine version. Probably the quickest fix.
ClotildeLouise
Unread post by ClotildeLouise » 27 Nov 2026, 04:21
Je pense que le problème pourrait résider dans la configuration du chemin d'accès des plugins VST. J'ai eu une expérience similaire avec une autre application audio, et réinitialiser le chemin d'accès au dossier des plugins a résolu le problème. Je vais vérifier cela et vous informer de mes résultats.
