diferences between USINE and USINE main in the dowloadable package
cybercharles
Unread post by cybercharles » 25 Jun 2008, 14:32
when you download the USINE package,
what are diferences between USINE app at the root level and USINEmain in files folder ? regards
charles
t
Unread post by senso » 25 Jun 2008, 17:38
Usine.exe is only a "loader" : when you run this program it only runs Usinemain.exe
and UsineMain.exe is the main application.
So you can use Usinemain directly...
Users browsing this forum: No registered users and 522 guests
