8 inputs / 8 outputs surround panning project — looking for advice
NikosT
Unread post by NikosT » 07 Jun 2026, 12:43
Hi everyone,
I'm working on a project that involves 8 audio inputs and 8 audio outputs, and I'd like to implement surround panning functionality similar to what the built-in modules SURR PAN SIMPLE, SURR PAN TRAJECTORY, and SMOOTH SURROUND TO PANNER offer.
I tried to replicate these features by copying and adapting the existing devices to work with an 8-input / 8-output surround setup, but the results were not satisfactory.
Could anyone give me some guidance or ideas on how to properly implement this kind of project in Usine? Any tips on routing, patching strategies, or custom module configurations would be greatly appreciated.
Thanks in advance!
Nikos T
Unread post by grego mondo » 07 Jun 2026, 14:01
Is that 8 simultaneous input or 8 independent input ?
What is not satisfactory for you ?
NikosT
Unread post by NikosT » 07 Jun 2026, 14:27
Sure, let me explain.
I need 8 independent inputs, each with its own panner. The idea is that each input can be routed to any of the 8 outputs independently — for example, input 1 to output 7, input 2 to output 3, and so on.
I'm also interested in using dynamic movement features such as LFO modulation and trajectory movement, similar to what SURR PAN SIMPLE, SURR PAN TRAJECTORY, and SMOOTH SURROUND TO PANNER offer.
The issue is that the existing ready-made devices only support up to 2 or 4 inputs. When I tried to adapt them to work with 8 inputs, the results were not satisfactory — the routing and panning behaviour did not scale correctly.
Nikos T
Unread post by grego mondo » 07 Jun 2026, 17:12
Well if it's 8 independant inputs then I would use 8 panners with only 1 input and 8 outputs
You can link all the parameters of the 8 panners so that : numbers of speakers / area / array speakers X and Y pos so they respond as "slaves" to a master panner (even with no sound in).
Hope it helps
NikosT
Unread post by NikosT » 08 Jun 2026, 08:06
Thank you for your response.
Nikos T
Unread post by oli_lab » 09 Jun 2026, 12:11
Hi nikos,
Greg solution is good to try, but you can also try this solution with audio matrix.
with it you can specify how each audio signal is spread on witch output. It is very interesting if you work with acousmoium-like speaker configuration as you can send one audio signal on many different speakers.
On dome like configuration, it allow for more bluriness and subtle movements within the sound !
audio matrix.wkp
(237.83 KiB) Downloaded 3 times
Unread post by grego mondo » 09 Jun 2026, 12:25
Hi
I obviously thought about Matrix but then you can't use lfo moving style
("I'm also interested in using dynamic movement features such as LFO modulation and trajectory movement, similar to what SURR PAN SIMPLE, SURR PAN TRAJECTORY, and SMOOTH SURROUND TO PANNER offer.")
Unread post by oli_lab » 09 Jun 2026, 13:43
grego mondo wrote:
09 Jun 2026, 12:25
Hi
a good thing to do is doing both : the matrix fo the texture and a surround panner for precise movement, LFO and what not.
althought, with the matrix solution, you can still make presets and switch from one to another one to simulate movements.
:D
Users browsing this forum: No registered users and 69 guests
