impossible to open Usine Win250605
XpiR
Unread post by XpiR » 17 Sep 2025, 13:06
Hi
I just lately downloaded the last version of Win Usine, but I'm not able to open it.
After an usual warning message by Windows Defender when I click the exe, (I choose "executer quand même") then absolutely nothing happens. No error message, no execution.
Shutting off Avast and Windons Defender doesn't change anything.
Have you ever faced this problem?
I still run my PRO version of 241127 without trouble.
Unread post by oli_lab » 18 Sep 2025, 00:34
- did you reboot your computer ?
- did you unzip the Usine package ?
- you can try to open it in administrator mode
XpiR
Unread post by XpiR » 18 Sep 2025, 10:18
Hi Oli
I've ever tried things you mentionned (unzip / reboot / admin mode) plus I downloaded the zip file once again from the BModular website.
Plus disabling my firewalls.
My process is the same as usual, and I updated Usine many times without any problem until now.
Unread post by oli_lab » 18 Sep 2025, 11:18
I try to upload it and open it and I have the same problem as you : there must be something wrong on the server side, I see to it with Senso
Unread post by oli_lab » 18 Sep 2025, 12:48
Found the culprit :
the windows Defender now blocks the usine.exe that you usually click on to launch Usine.
while Senso is working on it, there is a work around : open the "bin" folder and launch Usine.exe from here.
one this is done, the other usine.exe will work as usual.
XpiR
Unread post by XpiR » 18 Sep 2025, 14:25
So nice ! It works now.
Bon courage Senso...
Users browsing this forum: No registered users and 903 guests
