With the four midi output per track now, it would be great if we could choose on each midi out module wich output is assigned to...
It will allow to control up to four external harware for example, and mute them when we want, in only one track. the main idea behind this is to load on each track different set up for different songs: This way we could load up to ten songs per project!!!
Would it be difficult Olivier?
Midi out
- senso
no problem, for that you can use the "Interface Control/Usine Panels/Mixer Track Out" module.
With this module you have a total access to the track mixer settings in real time.
This is one of the main force of Usine: you can control everything!
