Nektar Pacer + Usine
daviche
Unread post by daviche » 06 Dec 2024, 15:38
does anyone uses the Nectar Pacer to control Usine ?
Anything to say about this controller ?
David
Composer - guitar player
Dell INSPIRON 16 5645
Windows 11
RME Fireface UC - EVO 8
Unread post by oli_lab » 09 Dec 2024, 22:43
Hi David,
I checked the specs of the Nectar Pacer : if it's to use it with Usine only, it is overkill !
maybe you'd be better off with a midi only pedal board as the Behringer FCB1010
the expression pedals will do wonders with Usine as well !
cheers.
daviche
Unread post by daviche » 17 Dec 2024, 14:27
Thanks.
The FCB1010 is too big, heavy and has no USB connection.
I may try the PACER, and send some feedback.
D
Windows 11
Unread post by grego mondo » 18 Dec 2024, 09:18
For smaller usb stuff, there's https://iconproaudio.com/product/g-board/
not so easy to find
Unread post by oli_lab » 18 Dec 2024, 16:56
grego mondo wrote:
18 Dec 2024, 09:18
not so easy to find
Hi, I saw this one or more exactly, I heard it : the switches make a awful lot of clicky noise !
good for heavy metal I suppose.
Unread post by grego mondo » 18 Dec 2024, 17:19
oli_lab wrote:
18 Dec 2024, 16:56
grego mondo wrote:
18 Dec 2024, 09:18
not so easy to find
Yes it makes noise (I forgot that !) but that's the smaller I know !
If size matters ...
Unread post by senso » 27 Dec 2024, 09:29
personally, I use
https://www.thomann.de/fr/line6_fbv_express_usb.htm. very good with an expression pedal and USB powered
for small interaction I use https://fr.audiofanzine.com/pedalier-co ... gidy/umi3/ also USB powered
Unread post by grego mondo » 29 Dec 2024, 11:22
It's funny,, here's what I use :
https://www.audiofront.net/MIDIExpression.php and piano pedals
it looks like the line 6 one ...
Unread post by oli_lab » 30 Dec 2024, 19:04
Mine is OSC ;-)
Unread post by 23fx23 » 10 Jan 2025, 12:22
Excellent, geat Look! Olie
Unread post by SylvainT » 11 Jan 2025, 09:55
Top, super beautiful. I love your vintage side, Olivar 😃
And it fits in my backpack... well, without the computer, without the sound card, without the other controllers. 🤣
