Video In From Tablet
halbius
Unread post by halbius » 25 May 2024, 12:34
on my tablet I use Krita for painting. The canvas i can put on a second screen (via USB-C to HDMI (or wahatever) adapter), without the toolbox, menu etc. being displayed. Just the canvas.
Now this canvas-only I want to have in Usine as video input, like it works with mobile devices camera via ip stream.
Does anyone know if this is possible?
I tried lots of things, but didn't found a solution.
Thanks a lot!
Unread post by oli_lab » 26 May 2024, 13:07
Maybe you can use NDI
https://ndi.video/tools/ndi-screen-capture/
There are NDI modules in Usine so you'll manage to get the stream from your tablet.
halbius
Unread post by halbius » 02 Jun 2024, 07:56
Thanks for that tip!
Unfortunately I only can access the camera or mirror the desktop, but I can not extend the desktop and output the canvas to a second screen.
Seems to be an android problem...
Unread post by oli_lab » 03 Jun 2024, 01:18
I didn't get it if you managed to put the drawing without tool box on a second screen, if so you may use a hdmi cable to go to an hdmi input to pc dongle. You should then get the video stream into Usine.
https://www.amazon.fr/adaptateur-hdmi-a ... mi+android
https://www.amazon.com/hdmi-input-pc/s? ... nput+to+pc
