Physics in XYZ-pad
halbius
Physics in XYZ-pad
Unread post by halbius » 27 Apr 2024, 08:49
I want to use the XYZ-pad with physics enabled, to move sources randomly in a 3D-room.
In the XYZ-pad I can only select 2D-views.
No I encounter the problem, that only the parameters shown in the view are moved by the physics:
- top view: x+y
- side l+r: y+z
- front+rear: x+z
Is this is a bug or is it ment to be for a reason?
Is it possible to get all three parameters moved by physics?
Thanks a lot,
Christian
Unread post by oli_lab » 27 Apr 2024, 18:36
the physic engine is 2D only, if you want 3d physics, an alternative is to use the engine of an extra XY pad (with one ball) to get the 3rd axis moving.
Or, use LFO's on X,Y,Z, it's cheap CPU wise and make up for smooth trajectory (lissajoux curves)
halbius
Unread post by halbius » 01 May 2024, 11:57
OK, thanks.
I had the LFO solution on my mind, but didn't know physics is 2D only.
Thanks a lot!
Users browsing this forum: No registered users and 234 guests
