Scripting Problem
styro
Scripting Problem
Unread post by styro » 14 Nov 2023, 13:41
Hi There!
trying to get my head on scripting: it has an Int-input for the state-nr,
but its only triggerd when it goes from 0->1 or 1->0 but not from 1->2 etc...
what am i doing wrong?
many thanks for some pointers!
all the best
styro
//GLOBAL VARIABLES AND TPARAMETER DECLARATIONS
var input : TParameter;
var PlayVideo : TParameter;
var VideoNr : TParameter;
var ShowPict : TParameter;
var PictNr : TParameter;
var CameraOn : TParameter;
var PlayAudio : TParameter;
var AudioNr : TParameter;
var test : TParameter;
//PROCESS
PROCEDURE PROCESS();
BEGIN
// VideoNr.asFloat(input.asFloat)
END;
//INIT PROCEDURE
PROCEDURE INIT();
BEGIN
// ModuleColor($FFBB41FF);
input:=CreateParam('in',ptDataFader,pioInput);
input.FastCallBack(true);
PlayVideo:=CreateParam('PlayVideo',ptDataFader,pioOutput);
VideoNr:=CreateParam('VideoNr',ptDataFader,pioOutput);
ShowPict:=CreateParam('ShowPict',ptDataFader,pioOutput);
PictNr:=CreateParam('PictNr',ptDataFader,pioOutput);
CameraOn:=CreateParam('CameraOn',ptDataFader,pioOutput);
PlayAudio:=CreateParam('PlayAudio',ptDataFader,pioOutput);
AudioNr:=CreateParam('AudioNr',ptDataFader,pioOutput);
END;
//CALLBACK
PROCEDURE CALLBACK(N:INTEGER);
var inval : single;
BEGIN
if N=input
then begin
inval := input.asInteger;
Trace('input has changed');
Trace(inval);
CASE inval OF
0: Begin
PlayVideo.asInteger(0);
VideoNr.asInteger(1);
ShowPict.asInteger(0);
PictNr.asInteger(1);
CameraOn.asInteger(0);
PlayAudio.asInteger(1);
AudioNr.asInteger(10);
End;
1: Begin
PlayVideo.asInteger(1);
VideoNr.asInteger(2);
PictNr.asInteger(18);
End;
2: Begin
VideoNr.asInteger(3);
End;
3: Begin
VideoNr.asInteger(4);
End;
End;//END MAIN CASE
END
END;
styro
Unread post by styro » 15 Nov 2023, 01:44
Found it out,
input.Max(20);
was missing...
Unread post by senso » 21 Nov 2023, 21:57
oky !
