HH5 Does not shut down properly
Hi all. I'm using HH5 latest version. I've reported this issue before and it has not been fixed. HH5 does not shut down properly, HH5 icon remains in the task bar after the program is closed. Sometimes it blocks the audio driver, some others it does not but the icon remains in the task bar forcing me to use the Windows task manager to completely shut donw HH. I've notice that the issue is more often presen with complex projects. in many cases HH freezes and crashes when trying to run it again.
It appears from time to time on MacOS too. But Usine is not the only one, one a while, it happens with Cubase too.
in most of cases a VST/AU plug blocks the shut down of Usine.
Hello. I have not been able to determine which VST plugin is causing this issue. I have severa plugins in the project and tested the all in different situations, one by one and combined and the results are not clear at this point. It seems that the issue appears when several of the plugings are working together. In any case this problem has to be corrected, it did not happen in previous versions of HH, it's being appearing for a while in newer versions of HH5. Didn't happen in HH4.
Users browsing this forum: No registered users and 504 guests
