What would be an ideal laptop configuration (Windows OS) to make the most of HH5 (and next HH6...)?
If you can come up with some models and brands I thank you in advance.
Laptop configuration
- rlgsbt
If you don't need to much real-time video, Dell XPS series are great.
But honestly, with I7 + 16go RAM, you can do everything you want in Usine. The soundcard and the ASIO drivers wil be important as well to manage latency
gurulogic
I am a fan of the business class of Lenovo laptops. Very reliable and not full of bloatware. That said, it is worth doing further research into any model you buy, especially for audio work. PC's in general are notorious for having driver (etc) conflicts that can cause unsatisfactory audio performance or require elaborate workarounds to get things running smoothly. "DPC latency" being a prominent point of concern.
You may find resources such as this one helpful, but best bet is to find feedback from others based on first hand experience with a particular model.
https://www.notebookcheck.net/DPC-Laten ... 376.0.html
