Converting CC value to DMX values
noise2sine
Is it possible in Usine to convert from a CC value module data into DMX values ? I have a patch which send CC values but i need that this patch can send CC values converted to DMX ?
Help !!!!
Thank you !
Help !!!!
Thank you !
I'm not sure to understand.
In Usine DMX is a value in the range [0..1] and CC is a value in the range [0..127]. So a simple change scale does the trick?
see
see
noise2sine
Thank you for your answer ! i'm sorry not to be clear ... If i understand well , there 's a DMX module that already do the job ? My need is to be able to send DMX values ? i have read that they are from 0 to 255 ? Do they can be sent through Midi out ? with a classic midi cable ?
Thank you !
Thank you !
Hi
If you want to strictly convert all CC input in dmx you can use the following script ( see example)
// MIDI CC to ARRAY
// Paramters declaration
var input : Tparameter;
var output: Tparameter;
var reset : Tparameter;
// initialisation procedure
procedure init;
begin
input := CreateParam('midi in',ptMIDI,pioInput);
output := CreateParam('array out',ptArray,pioOutput);
output.Min(0);
output.Max(1);
output.Length(128);
reset := CreateParam('reset',ptButton,pioInput);
ModuleColor($FF3298DB);
end;
// Global Variables
var MIDI : TMIDI;
// Main Loop procedure
Procedure Process;
var i: integer;
begin
output.Length(128);
if reset.equal1
then begin
for i:=0 to 127
do output.asArray(i,0);
reset.asFloat(0);
end;
for i := 0 to getLength(input)-1
do begin
MIDI := input.asMidi(i);
if (MIDI.msg=176)
then begin
output.asArray(MIDI.data1,MIDI.data2/127);
end
else
if (MIDI.msg=128)
then begin
output.asArray(MIDI.data1,0);
end;
end;
end;
- CONVERT CC TO DMX.wkp
- (135.87 KiB) Downloaded 463 times
Dmx won't go thru midi output
You'll need a dmx interface
Check dmx king
Check dmx king
noise2sine
Thank you for your precious help . My need was to generate a CC automation curve in usine and send it to a machine that only get DMX input . i thought that it would have be possible to convert the CC signal but i didn't think about the cable issue !!! So in fact i need to still send CC values through midi but in a midi to DMx box !
Can you give me advice for a midi to DMX box ?
Thanks again
Thanks again
The easy and robust Way is with a dmx king edmx artnet to dmx interface.
Comes with a cost for sure.
There's a usb to dmx thingo from dmx King that is a cheaper alternative.
Midi To dmx interface doesn't exist. It's too much different protocols .
You have to make the conversion with usine and send dmx flow directly on a dmx interface.
Users browsing this forum: No registered users and 316 guests
