Hey!
I did a workspace with lot of sends (Rack to rack). Each send is controlled by a faderfox but for an unknown reason some racks don't keep the midi assignation for the sends after saving the workspace. When I open the workspace again, it lost the assignation.
I don't understand because I did the same for other racks and it works fine.
Any idea ?
Thanks !
Midi Control problem after saving
can you try the latest beta version ?
Hey
Thanks for the answer.
Unfortunately it doesn't change. It's a bit random. If I change the order for the outputs (adding an output for example) the midi assignments change too. There is something that we have to do not to have this kind of problem ?
It's very strange, I'm trying and trying again to find what are the parameters that cause this phenomena. I really don't find.
It's quite hard because all my workspace is based on the send and the midi assignations .. If I can't be confident on the save... I loose a lot of time trying assign midi for nothing.
I would be very grateful if you can help me for this.
the only solution is to send your wkp (or a simplified version) to the support with explanations.
Ok, thanks.
I will take time to do this soon.
Thanks again !
Thanks again !
