Midi Control problem after saving
JF
Unread post by JF » 26 Apr 2022, 11:12
Hey!
I did a workspace with lot of sends (Rack to rack). Each send is controlled by a faderfox but for an unknown reason some racks don't keep the midi assignation for the sends after saving the workspace. When I open the workspace again, it lost the assignation.
I don't understand because I did the same for other racks and it works fine.
Any idea ?
Thanks !
Unread post by senso » 28 Apr 2022, 11:29
can you try the latest beta version ?
JF
Unread post by JF » 01 May 2022, 17:43
Hey
Thanks for the answer.
Unfortunately it doesn't change. It's a bit random. If I change the order for the outputs (adding an output for example) the midi assignments change too. There is something that we have to do not to have this kind of problem ?
JF
Unread post by JF » 01 May 2022, 23:51
It's very strange, I'm trying and trying again to find what are the parameters that cause this phenomena. I really don't find.
It's quite hard because all my workspace is based on the send and the midi assignations .. If I can't be confident on the save... I loose a lot of time trying assign midi for nothing.
I would be very grateful if you can help me for this.
Unread post by senso » 02 May 2022, 10:48
the only solution is to send your wkp (or a simplified version) to the support with explanations.
JF
Unread post by JF » 02 May 2022, 12:12
Ok, thanks.
I will take time to do this soon.
Thanks again !
Users browsing this forum: No registered users and 197 guests
