HH5 v5.2.220218 does not mantain VST GUI position
Hello All. Previous version did it. Usine was able to keep the selected position of VSTs. Now when you open them they do it at a specific XY cordinates of the screen and not at the selected position. For me this is kind of an issue because with previous versions of HH I could open several VST GUIs each opening at its desired selected position, this way I could have several VS GUIs open in a organized way on the screen. Any way to tweek Usine and solve this?
looks more as a bug report ?
We'll check
We'll check
not realy.
You can try the following tweak:
replace the file /resources/devices/PluginWrapper.usr-win64 by the attached file?
- PluginWrapper.zip
- (1.13 MiB) Downloaded 483 times
Thanks Senso. So far the tweak seem to be working.
Users browsing this forum: Bing [Bot] and 115 guests
