I posted this on the end of another message and I think it kind of got lost.
I was experimenting with the patch on/off and and patch bypass modules, and I found that when one of these is connected
to the patch logic, it changes what the logic before it does. It is as if Usine knows there is a patch on/off module connected and still
runs the logic leading up to this module even though the patch is "off". This enables the patch to be switched back on despite the patch containing the logic being "off".
Is this intentional functionality in Usine, or is something else going on ?
I wonder if Senso can comment, since I would like to know if this behaviour is reliable.
patch on/off and bypass.
Yes all the modules connected to (and before) the path-on-off are calculated all the time. So the patch can calculate the patch-on-off module and turn it on/off on demand.
Users browsing this forum: Bing [Bot] and 445 guests
