Strange no-sound behaviour experienced
Lioness
Unread post by Lioness » 03 Dec 2021, 12:58
Hi there,
this is my first post here - I am still relatively new to the use of Usine, and I may be looked after if I think something is a bug here and there, which is perhaps just a misunderstanding by me with the complex software.
My first question: I have a grid element in grid mode that contains a rack with two patches: in the first patch a midi file is loaded into the piano roll and that controls the subsequent VST synth patch. Works fine and I get the sound and melody I want.
But now the strange behavior that I don't understand: When I leave grid mode (and it happens, regardless of whether I still have the rack as a grid element at that time or have removed it from the grid), then the Audio signal no longer leaves Usine. And this although the output meter shows that sound is being generated and the tracing of the wires in the output device also shows the audio signal flow is active. However, no sound arrives at the physical output device any longer. I have to restart Usine to get sound output again.
Where is the mistake I'm making, or is it a bug? I am using the current version of Hollyhock Pro (5.1.211124). This behaviour happens regardless the VST plugin I have used in the described situation.
"Playing is an activity that cannot be taken seriously enough." (Jacques-Yves Cousteau)
Unread post by senso » 04 Dec 2021, 08:10
Nothing strange reported at the support. Can you join an example as attached file ?
Lioness
Unread post by Lioness » 04 Dec 2021, 10:08
Maybe a stupid question, but: what kind of file/content would be helpful here for you? Saved workspace?
Unread post by senso » 04 Dec 2021, 19:29
a simplified workspace to be able to reproduce the problem.
also the LogFile.Log inside the packet of Usine.
Users browsing this forum: Bing [Bot] and 108 guests
