before installing HH5 I'd like to know the compatibility and procedure to migrate presets and settings.
many thanks
HH5/HH4 presets and settings compatibility
Hello? I think there is no difference between HH4 and HH5 ( only while upgrading) But you should easialy try it by open your projects on HH5 before deleting HH4
I opened an HH3 workspace in HH5 OK (apart from a VST window bug I have reported).
settings import is not compatible, you can only import settings from older HH5 builds.
as for patches etc, most stuff should work, I think the only thing that may cause problems is some scripts in script module could cause error, but fixing the code of the script can solve this if there's a problem. or if script was used from library, you just replace it with new one (like MIDI to Array script for example). and sometimes layout of your patches may be messed up a bit.
Users browsing this forum: No registered users and 92 guests
