I don't know why, I get this error message when trying to open a workspace with the 200619 version "The project was generated using a newer version of the application. Please upgrade your copy to recall the project". The 200619 is the last version isn't it?
And after that message Usine Freeze
Usine 200619
Have you this message with all your projects or only one ?
Can you please unzip a fresh version of Usine, load this project and send us the log file to support@brainmodular.com ?
The issue was hapenning with only one workspace. After times the error message did not appear any more, but Usine crashed. I supressed a Kontakt instance with a previous Usine version and now it'is fixed. I don't really understand where the problem came from. But now it works and it is the main thing.
Thanks for answer
Thanks for answer
good news,
and yes, Kontakt is sometimes an issues source.
Users browsing this forum: No registered users and 93 guests
